RJ65 Rear Disk Question
Old Mar 29, 2006 | 07:53 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
when changing rear pads, are they the same pad as the front? (154's?)
also is a special tool need to compress the rear caliper?
What size rotor can i upgrade to?
can i get a bracket and easily add LS1 rotors/calipers or or 1le's?
would i need different e-brake calbes, hoses etc.?
just wondering what the rear dis brake options are, and how easily they can be done/afforded
this is on a 88 formula 10 bolt rear
Old Mar 30, 2006 | 01:02 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The pistons in those "old" style calipers twist in, you'll need the tool for it or a pair of needle nose pliers and a steady hand will work as well. You can't really increase the size of these rotors as the caliper is bolted in a fixed location. As for upgrades to these brakes, install the recall kit, upgrade the pads and rotors. For what it's worth, I'd still recommend the upgrade to 12" PBRs which give you more options with pads and rotors.
Ed
Old Mar 30, 2006 | 10:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's an option: https://www.thirdgen.org/forums/show...hreadid=249098
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
