Whats this thingy?
Old Apr 14, 2006 | 07:11 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
Whats this thingy?
Old Apr 14, 2006 | 08:56 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's a brake line. There are three lines coming out of the proportioning valve - 1 line runs to the rear brakes (gets different pressure levels) and the other two run to the fronts, 1 to each side.
Old Apr 14, 2006 | 09:31 PM
Car: IROC Z
Engine: 5.7
no, i didnt circle the brake line, ill see if i can get another angle
its a sort of a black plastic nipple coming off the back of the whole assembly.
Old Apr 14, 2006 | 09:41 PM
Car: IROC Z
Engine: 5.7
Old Apr 15, 2006 | 07:30 AM
Car: 1992 RS
Engine: Carbed 350
"Oh - I see" said the blind man!
Um, I don't know what it is - it's like a rubber or plastic cap right? All of them have it. That's one of those things (in my world) where if it ain't broke, I don't mess with it LOL.
I believe I've seen articles on here that describe removing it, and maybe a screw behind it, and drilling out inside there, replacing the screw (maybe a longer one or something) and getting different line pressure for brakes - for whatever reason. Maybe try a search on proportioning valve mods, or check the tech section for an article - I know I saw something on here about it.
Old Apr 15, 2006 | 06:13 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
under that black rubber thingy is a place where you can unscrew, i believe, cant remember, to take out the tension spring and a valve to allow certain amounts of brake fluid to the rear and front brakes, i took my apart a couple years ago to adjust for swapping drum to disc brakes.
Old Apr 15, 2006 | 06:34 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
That's the cover to the screw that allows you to remove all the internals of the valve, I don't recommend screwing with it.
Ed
ZZ42Fast
Aug 30, 2015 02:39 PM
Sleipnir
Oct 18, 2001 06:24 PM
breathment
Oct 17, 2001 08:37 PM
Sleipnir
Oct 4, 2001 06:38 AM
One Eyed Jack
Jun 17, 2001 06:27 PM
