Why no E-brake w/PBR?
Old Apr 16, 2006 | 09:48 AM
phishfud's Avatar
Car: 88 GTA
I did the rear PBR swap last year, and even though the brakes work great, I still have no E-brake. No matter how I adjust the cables (above the driveshaft), when I pull the handle, it gets stiffer, but the e-brake doesn't work. Anyone have any ideas as to what I need to adjust or look for? These are the 89-92 PBR brakes, and yes I have new cables. I need the e-brake to pass PA inspection, so leaving it not working is not an option. Thanks for any help.
Terry
Old Apr 16, 2006 | 08:19 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
I'm having the same issue. Have you checked to make sure when you pull the handle that the cable actually works. I planned on doing it this weekend but couldn't get the wife to help. Just pull off the wheels and have some one sit in the car while you watch the cable to make sure its operating the lever.
Old Apr 17, 2006 | 07:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the "free travel" link in the following:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Apr 17, 2006 | 08:58 AM
phishfud's Avatar
Car: 88 GTA
Thats what I needed. I thought the only adjustment was above the driveshaft, so I guess I have some work to do. Looks like those scanned pages are right from the service manual, which luckily I have. Thanks for the info.
Terry
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
jawzforlife1
Apr 25, 2002 03:36 PM
The Dirty Bird!
Apr 1, 2002 02:36 PM
88transam5.0
Dec 19, 2001 06:58 PM
Rob -Formula-
Jul 28, 2000 08:46 PM
