Replacing Drum brakes
Old Apr 18, 2006 | 06:08 PM
Quick-IROCZ's Avatar
Car: 1987 IROC-Z28
Engine: 305 Tpi
Is there a picture or diagram of a drum brake from an Iroc, so i know how everything goes (I already took both sides apart because I'm sanding and painting and mechanical arms and other things).
Also, how can I depress the parking brake spring to get the arm back on? it was a lot of work getting it off.
Old Apr 18, 2006 | 07:29 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
check out:
</title></head>");
newWindow.document.writeln("<body><div align='center'><img " + getWidth("yes") + "src='/images/cds/" + tpe + "/" + sze + "/" + pc + "." + tpe + "'></img></div>");
newWindow.document.writeln("<div align='center'><table><tr><td><FORM><input type='button' name='sized' value='" + getButtonValue("yes") + "' onClick='javascript:window.close();opener.pop(\"" + pc + "\",\"" + tpe + "_" + sze + "\",\"" + getValueToPass("yes") + "\");'></FORM></td>");
newWindow.document.writeln("<td><form><input type='button' value='Close' onClick='javascript:window.close()'/></form></td></tr></table></div>");
newWindow.document.writeln("<br/>");
newWindow.document.writeln("<div align='center'><font face='Veranda, Arial, Helvetica, sans-serif' size='-2'>Copyright &copy; 2002 Delmar, All Rights Reserved.</font></div></body>");
newWindow.document.writeln("</html>");
newWindow.focus();
newWindow.document.close();
newWindow.print();
function pop_norm(pc, tpe, sze)
newWindow = open("","","directories=no,menubar=yes,toolbar=no,location=no,scrollbars=yes,resizable=yes,height=400,width=700,left=50,ScreenX=50,top=120,screenY=120");
newWindow.document.writeln("<html><head><title></title></head>");
newWindow.document.writeln("<body><div align='center'><img " + getWidth("no") + "src='/images/cds/" + tpe + "/" + sze + "/" + pc + "." + tpe + "'></img></div>");
newWindow.document.writeln("<div align='center'><table><tr><td><FORM><input type='button' name='sized' value='" + getButtonValue("no") + "' onClick='javascript:window.close();opener.pop(\"" + pc + "\",\"" + tpe + "_" + sze + "\",\"" + getValueToPass("no") + "\");'></FORM></td>");
newWindow.focus();
function getValueToPass(valPassed)
if(valPassed == "yes")
return "no";
else
return "yes";
function choose(formAction)
with (formAction)
ref=options[selectedIndex].value;
document.location=ref;
function getButtonValue(val)
if(val == "yes")
return "Enlarge Image";
else
return "Print Image";
function getWidth(prnt)
if(prnt == "yes")
return "width='650' ";
else
if(prnt == "no")
return "";
</script>
<title>AutoZone.com | Repair Info | GM Camaro 1982-1992 Repair Guide | Brakes
There are tools specially designed to help get the springs back on, and get them off easier - a set of brake tools like $15
MAKE SURE you don't get the adjusting assemblies mixed up from left to right (pass side vs. driver side) - otherwise, you'll be tightening your drum brakes everytime you brake forward, instead of when you brake backwards.
wow - something went wrong there - sorry!
Last edited by camaronewbie; Apr 18, 2006 at 07:30 PM. Reason: Automerged Doublepost
Old Apr 21, 2006 | 07:49 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I was always told when you do drum brakes to do one side at a time so if you forget where something goes you can look at the other side to get an idea where it goes. That and so you dont mix parts side to side
ZMWojnar
Brakes
May 12, 2019 10:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
