Master cylinders the same?
Old Apr 27, 2006 | 01:22 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
I searched and found a couple of threads but I need more info.I just swapped out my drum rear for a disc.I got the prop valve and rearend off the same car so I know they match.I pulled my old master cylinder (part # 18006814 A50) and I got another master for disc/disc from a friend,that part # was the same as mine,are they the same for drum and disc?Right now with the new one my pedal goes to the floor and my brake light comes on.I have bled the system 3 times now.It stops but now really well,or safe.Any info?
Old Apr 27, 2006 | 12:06 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
The prop valve and rear came out of an 86 iroc,if that makes a difference.These are the #'s on the side of the prop valves I have
The one I took off the car - NC-31-KH-2588
The one I got with the other master cylinder - MB-35-KH-1669
The one from the 86 Iroc - MB-33-KH-066 6
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
