PBR/9 bolt swap= wheel hitting caliper???
Old May 4, 2006 | 06:43 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
I just got around to boltin up my 16" IROC wheels to the new 9 bolt/PBR setup and noticed that the driver side rear wheel is just barely rubbing against the caliper, and the passenger side is a little too close for comfort. I remember seeing somewhere on here, or in the parts catalog, where the IROC wheels had spacer. Is this the reason? I cannot figure out why its hitting, I could probably grind some off (it looks like its just hittin the fins), but Id rather not. ANyone help me here?
Old May 5, 2006 | 06:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The spacer came with drum brakes. I've completed the PBR swap on my IROC and I experienced no fitment issues with my stock 16's.
JamesC
Old May 5, 2006 | 10:23 PM
spills's Avatar
Car: 89 RS
Well for some reason mines hitting, or I guess I should say rubbing a good bit. Anyone have anyidea as to what caused this? Im also wondering if its a slightly bent axle, in which case Ima be pissed
Old May 5, 2006 | 10:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That is a bit strange, considering those brakes should fit with stock 15s even.
Old May 5, 2006 | 10:50 PM
spills's Avatar
Car: 89 RS
Do you think it could be a bad axle? I mean worse comes to worse I can put some washers or a plate behind the wheel to space it out enough to turn, put it up on jackstands and run it to see if its wobboling. But Im not 100% sure thats the problem. I mean its barely hitting it, just enough to take the paint off. But its hitting nonetheless.
Old May 5, 2006 | 11:43 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
sounds like that is whats going on. that or perhaps you used the wrong bracketry or somthing. i have 15"s (for now) on my GTA with no fitment issues with my 9bolt/PBR brakes. aftermarket 15"s not stock
Old May 6, 2006 | 05:28 AM
JamesC's Avatar
From your description, something seems to be putting the calipers too far outward.
https://www.thirdgen.org/forums/atta...g?d=1087747369
Whatever the problem, I'd attempt to fix it correctly rather than to doctor the situation with spacers.
JamesC
Old May 6, 2006 | 04:07 PM
spills's Avatar
Car: 89 RS
Wow, ok so I might be taking a week off or working cars.....
Turns out there is a difference between INSIDE and OUTSIDE pads. Had em swapped, one of em has humps on it that rides on the piston, and it wasnt, pushing the caliper outwards. Note to self: Check EVERTHING before you start going out and pricing axles lol. Thanks for your help guys, I never even would have thought to check that out.
1984HO
Mar 19, 2021 11:59 AM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
red90IROCls1
Aug 25, 2015 06:56 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
