More 6 piston stuff...
Old May 15, 2006 | 07:56 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
I noticed these on jegs... now keep in mind that I really want to keep the car looking stock.. well I need to since very shortly I will applying for classic status(I can't afford insurance otherwise). Its basically what I wanted to spend for an entire brake package but what the hell..lol
JEGS High Performance - Wilwood Camaro/Firebird 6-Piston Brake Kit
They are for the 4th gens... Anyone have exprience with these they weren't available all to long ago. I wanted to know if they could be easily mounted and if they would clear Stock 16" Iroc-Z Rims. The idea is to not make my upgrades to the car apparent while maximizing performance. Still trying to figure out what Im going to get. The nice cheap Corvette C6 Z06 PBR's are out of the question because I need to retain my stock Rims and rear axle.
Edit: can brakes designed to run on abs run on a traditional locking brake system.. I hate ABS its for people who cant control themselves when something happens.
Old May 15, 2006 | 08:15 PM
iroctj's Avatar
Car: 86 IROC-Z
Engine: 385 TPI
Transmission: 700-R4
Axle/Gears: 9Bolt 345'S
I thought u should know that these brakes won't work on a 3rd gen car, 1le or not.
Old May 15, 2006 | 08:36 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
what about a c5 modification to the spindles? removal of the ears and drilling etc. I wasn't really worried about them bolting on. I can bolt on C6 Z06 brakes, what Im worried about is if they will work and if they will fit the wheels.
C5 caliper conversion...
http://82lt1.cz28.com/brakes/page5.html
C5 Wilwoods.. difference should be in the caliper and rotor.. otherwise its supposed to be a direct swap...
http://wilwood.com/Centers/Informati...let/c59704.asp
Now that I look at the pricing even cheaper would be the LT1 Camaro Conversion... Unless the C5 conversion would be the same as the 98-02
Old May 15, 2006 | 09:32 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I've done C5 calipers with a LS1 rotor and they fit inside 16" rim:
https://www.thirdgen.org/forums/brak...s1-rotors.html
Also, that 6 piston setup just may fit if you use LS1 hubs and brackets, you can't use the Wilwood hubs but the rest will likely bolt on. You could always send them back...
Ed
Old May 18, 2006 | 01:36 AM
2tone's Avatar
Same 4th gen kit shown above fitted to a third gen- Would ya looky there....
Guess it can be fitted to a third gen.
The whole build is documented on TGO
There are 3 different threads of info. Here they are in order of start to finish.
https://www.thirdgen.org/techbb2/show...hreadid=245273
https://www.thirdgen.org/techbb2/show...hreadid=261639
https://www.thirdgen.org/techbb2/show...hreadid=268722
Rears-
https://www.thirdgen.org/techbb2/show...hreadid=216339
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
