Slightly different big brake upgrade
Old May 18, 2006 | 01:13 AM
Spifz's Avatar
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
It's probably been done, but here is a 13" (1.10 thick) 1996 corvette rotor with a Wilwood forged superlite 4 x 1.75" piston caliper. The hub assembly is the stock part with the rotor machined off and turned down to 5.900. The stock caliper ears are cut off the upright, and two of the dust shield holes were enlarged to 1/2-20 for new caliper plate, which is 3/8". I didn't turn any material off the face of the hub because I wanted to space the front wheels out just a little bit more. (The rotor moves them out .297) If you turn .161 off the hub face, then the caliper lugs would line up with the upright lugs perfectly and you wouldn't need to machine a step into the caliper plate like I did. I ran some stress analysis, just for fun. The caliper plate is under a hypothetical 1.2 G braking force (about 1200 ft-lbs at the wheel.)
Attached Thumbnails Slightly different big brake upgrade-brake1.jpg   Slightly different big brake upgrade-brake2.jpg
Old May 18, 2006 | 01:14 AM
Spifz's Avatar
The actual pictures:
Attached Thumbnails Slightly different big brake upgrade-brake3.jpg   Slightly different big brake upgrade-brake4.jpg   Slightly different big brake upgrade-brake5.jpg
Old May 18, 2006 | 07:22 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yes, been done before by myself here:
https://www.thirdgen.org/forums/brak...light=wilwoods
and Dan "Machinist" offered them with Spohn but they aren't on his website anymore....
Ed
Orr89RocZ
Apr 25, 2016 08:28 AM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
lt1z350
Aug 28, 2015 05:57 AM
zayne0
Aug 24, 2015 07:22 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
