anti seize on bleeder screws?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Is this a no no or anything? I'm going to remove and replace my mangled ones in the front and was going to use antiseize on the threads, but I figured i'd check, in case the stuff screws up brake fluid or something scary....
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
I have used thin coat antiseitze(fel-pro)in brakecaliber bleed threads,no disadvantages with antiseitze.
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
