Prop Valve Mod
Old May 17, 2006 | 09:37 AM
L.I.N.Y.92CAMARO's Avatar
Prop Valve Mod
I was Going To do the prop valve. mod this morning when i went out to my car and the bleeder valve where you put the set screw in has a brake line going to it? Anyone know if i can still do this somehow?
This Is What i was talking about. 1988 Chevrolet Camaro - Jeff's Chevrolet
Thanks,
Old May 17, 2006 | 06:11 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
hm the page clearly states if you have 89-92 rear brakes do not do this modification. I am assuming you have a different setup. Perhaps more of a combination valve then just a proportional valve. Metering and proportional
Old May 17, 2006 | 08:51 PM
87irocz28_383's Avatar
Car: 87 iroc z28
Transmission: 700-r4
Axle/Gears: 9-bolt, 3.27 gears
so with that mod do u put the spring and piston back in??
Old May 20, 2006 | 08:10 AM
No just the set screw.
Hotrodboba400
Dec 10, 2019 07:07 PM
corey8084
Sep 17, 2015 02:56 PM
355tpipickup
Sep 13, 2015 11:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
