disc vs drum master cylinders
Old May 17, 2006 | 01:14 PM
age's Avatar
age
Car: 1992 Z28 1LE
I was wondering if anyone has a link or knows the two digit/alphabet code that would identify a disc/disc and a disc/drum master cylinder?
I just checked a couple of 3rd gen camaros, and I have a feeling that:
1) "FX" = disc/drum
2) "FY" = disc/disc
are there any other codes that GM used throughout the years for the 3rd gens, or are those two pretty much it?
thanks!
Old May 17, 2006 | 05:36 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Not sure a master cylinder change is necessary when swapping from drum to disc (or visa versa). I didn't do it - I just swapped out the proportioning valve when I installed my LS1 rear since there is a difference in how much fluid is sent to disc vs. drum. No one that swaps to rear discs does master cylinder that I have heard of.
Old May 17, 2006 | 07:03 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Poster, you have a '92 year car... all master cylinders were the same for all cars years '91 and up, yours will be the same no matter if you have disc or drum or want to upgrade. Keep the one you have.
But per your question, the stickers are the only way I've been able to tell them apart.
Ed
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
codeysabatini
Nov 10, 2015 04:07 PM
camaro1185
Oct 26, 2015 06:51 AM
