SEVERE BRAKE DRUM SQUEAL!!!!! HELP
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
REAR DRIVER SIDE DRUM MAKING SOME SERIOUS SOUNDS
SHOES WERE GLAZED SO I SANDED THEM DOWN WORKED/SOUNDED GREAT AFTER ABOUT 5 MILES OF NORMAL BRAKING SOUND SLOWLY REAPPEARED
CHECKED E-BRAKE = WASNT HUNG UP BUT SHOES WERE RESHINED AGAIN DRUM IS SHINY AS WELL DUNNO IF DRUMS ARE GLAZED OR NOT GONNA RESURFACE EM I HAVE GOOD QUALITY SEMI-MET SHOES THIS NOISE WASNT HERE LAST SUMMER AND SHOES ARE 1 YR OLD COULD IT BE SOMETHING INTERNAL ?
ALSO DRUM SPRINGS & WHEEL CYLINDERS ARE FRESLY INSTALLED
THE SCREAMING NOISE IS ONLY HEARD WHEN APPLYING THE BRAKE AT A NORMAL FOOTING DURING HIGH SPEED SLOWDOWN OR AT LOW SPEEDS LIGHTLY TAPING THE PEDAL ...ITS DRIVING ME BONKERS HELP !!!!!!!!
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
I HEAR YA !
So far you did everything right.
It SOUNDS(sorry bout dat)
like you shoes are reglazing. Try using OEM shoes to make sure
you’re getting the correct compound.
“If people drove any slower
they’d be going backwards.”
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Might as well get a set of shoes at autozone or something they are very cheap and a pack of brakeware. thats like 5 bucks and replace all the springs and shims and whatnot. You should be golden then. Do not use some old shoes laying around.
Hotrodboba400
12-10-2019 07:07 PM
Night rider327
09-02-2015 04:17 AM
