C-5 Caliper Clearance
Old May 22, 2006 | 06:48 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Ed, this one's for you or anyone else who can answer this. I have my C-5's installed and I have to use a 1/2" spacer to push the wheel out off the caliper, and I had to do a little radiusing of the caliper on the front to gain more clearance, as for the radiusing, I'm not going to be autocrossing this car so I hope it won't hurt anything. My question is this, how much is the minimun clearance you can have between the wheel and caliper? Do you have to account for expansion of the aluminum caliper when it heats up? Right now, I have about .50-.52 thousandths. Is this enough and what happens as the brake pads wear, does the caliper move to towards the wheel? The design of the spokes on this wheel are right on top of the caliper even though they are 17's. I am looking for advice and help here, since I want to get my car out for cruising. Thanks in advance..
Old May 22, 2006 | 08:05 PM
Poltergeist's Avatar
Car: 2002 Camaro SS / 1982 El Camino
Engine: LS1 / LT1 in the El
Transmission: A4 in both
Originally Posted by cc 82Z-28
..... what happens as the brake pads wear, does the caliper move to towards the wheel?
I can't help on most of this but the caliper moves away from the wheel. The opposite of piston travel. I just finished mocking up my C5 set and I have just short of 1/8" clearance. I've seen a Corvette Baer had a few years ago I don't think you could have fit a business card between the wheel and caliper. The owner of Baer just said "clearance is clearance".
Old May 23, 2006 | 05:35 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Cool!! I have about a little less than 1/4" at this point and I think I will give it a try, Thanks for your input on this..
Old May 23, 2006 | 09:39 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yes, like Rob said, as the outer pad wears down, the caliper will move inward. Your clearance sounds like enough. I doubt the caliper will expand enough to give you an problems, and 1/4" is plenty.
Ed
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
91 SrS
Oct 7, 2015 04:32 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
