PBR Brakes
Old May 28, 2006 | 01:56 AM
kalel21's Avatar
Car: 91 Z28, 86 Z28
Engine: 5.7 TPI, 5.0
Transmission: 4L60E/transgo shift kit
PBR Brakes
Need help in finding the part/'s which holds the brake pad in the caliper (anti rattle spring). Not sure if that's what it's called for the pbr brakes. I bought new brake pads and they didn't come with it and auto stores don't seem to carry it. A part number would be nice or at least to be pointed in the right direction. Thanks!
Old May 28, 2006 | 08:02 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The new pads, or the ones I've dealt with, should have had those springs on them. My EBCs did. Like I said I have extras if you need some.
Ed
Old May 28, 2006 | 06:58 PM
kalel21's Avatar
Car: 91 Z28, 86 Z28
Well I checked at my local auto stores and asked them if they could check with all the different types of brands to see if any carried the clips and non did. Yes, Ed I would appreciate if you could send them to me. PM me with more info.
Old May 28, 2006 | 07:47 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
They come in the caliper hardware kits from NAPA. I had to buy the kits when I did my swap. It had the clips, the retainer pin and an e-clip.Brake Caliper Hardware Kit - Front Item#: UP 83014 Price: $8.49 . This is from the website, there is a picture there.
Old May 29, 2006 | 04:43 PM
kalel21's Avatar
Car: 91 Z28, 86 Z28
Will those clips fit the rear calipers? Because I need them for the rear brakes.
Old May 29, 2006 | 11:20 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I thought you meant the fronts. I don't remember clips on the rear. Do you have pics?
Old May 30, 2006 | 01:37 AM
bluethunder28's Avatar
The rear PBR pads don't use a clip. They have a spring on the top.
Old May 30, 2006 | 02:38 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
That is what I thought. They fit in the carrier and the springs hold the caliper tight. I wasn't sure if he had something different.
Old Jun 9, 2006 | 07:36 PM
kalel21's Avatar
Car: 91 Z28, 86 Z28
Well I finally went to the dealer and they cant seem to find the spring part. But I did notice that I'm also missing a shim that's shaped like an H. Which comes with the stock brake pads that are $95.00 Well do any of you guys know where else I can find these parts?
Old Jun 9, 2006 | 08:47 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
The only brakes I can think of that use something similiar is the delco rear disks on pre-89 cars.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
