9bolt rear disc?
Old Jun 13, 2006 | 01:04 AM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
9bolt rear disc?
Which way do the calipers face on a 9bolt. I noticed on mine that the drivers is facing the rear. And the passengers is facing the front. Is this right or is my car screwed up more then I thought. Thanks in advance for the help! Adam :-)
Old Jun 13, 2006 | 01:34 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That's normal.
Old Jun 13, 2006 | 01:45 PM
IT IS! I never seen a car like that before. Adam :-)
Old Jun 13, 2006 | 01:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not so normal for other cars. Normal for thirdgens with Delco-Moraine calipers, though.
Old Jun 13, 2006 | 01:57 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Yup. With 89 and up rear ends the calipers both face forward.
Old Jun 13, 2006 | 05:23 PM
Well that's stupid. Atleast it's not just my car and it's suppose to be like that. Thanks for the help! Adam :-)
Old Jun 13, 2006 | 06:47 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
That's just GM saving money... by using the same caliper on both sides they didn't have to have two models made, just swap sides and use the same backing plate, caliper, and rotor on both sides. Lazy but cost effective.
Ed
Old Jun 13, 2006 | 07:50 PM
It maybe more cost effective. But I still think it's stupid.
Old Jun 14, 2006 | 05:58 PM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
Normal for the rear but would sugest looking into a diffrent rear if you plan on any power, my 9 bolt has been rebuilt 3 times, im now saven for my 9 inch, and babying the 9 bolt.
Old Jun 14, 2006 | 09:15 PM
By the time I build a motor to blow the rear up. I'll have a 12 bolt in it's place. Adam :-)
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
