Prop Valve Question
Old Jun 18, 2006 | 08:58 PM
JB22's Avatar
Prop Valve Question
I just swapped a 91Z PBR Disk setup into my car.
I have the prop valve out of the car that the rearend was in, my question is, can I just swap out the internals of the prop valve so I dont have to remove the entire setup from the car?
Reason I ask is that I remember reading that brake line fitting sizes changed mid year in 89, so the lines I have in my car (88) likely wont fit the 91Z valve I have.
So... what is the best plan of attack?
Old Jun 24, 2006 | 12:39 PM
JB22's Avatar
anyone?
Im assuming my rear brake pressure wouldnt be too good if I left the stock 88 rear drum prop in the car with the new PBR's in the rear?
need some advice here guys.
Old Jul 19, 2006 | 02:18 AM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Axle/Gears: Moser/Strange 9"
would also like to know about this.....
Old Jul 19, 2006 | 05:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
GM 14089496 1989 1st design: M1.0 tube nut threads (For 1982 - early 1989 applications). GMPartsDirect, $57 plus change.
JamesC
69 Six Pack
Oct 5, 2015 07:51 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
