Master cylinder and Breaks
Old Jun 19, 2006 | 05:47 PM
Brandon1990RS's Avatar
Ok this might sound stupid but i installed new calipers and pads on the front, bled the drivers side fine, but the passenger side is not getting any fluid whatsoever, half of the master cylinder is empty, half full...which part of the cylinder is for the front breaks and which is for the back? or is it split by sides? thanks
Old Jun 19, 2006 | 09:02 PM
92zcamaroperson's Avatar
Car: 92 z28 25th
Engine: 5.7 liter
Transmission: 700-R4
did you bench bleed the master cylinder? This is very important. Both halfs of the master cylinder should have fluid. Its separated front and back. Did you replace the break hoses too?
Old Jun 21, 2006 | 02:26 AM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
Originally Posted by Brandon1990RS
...bled the drivers side fine, but the passenger side is not getting any fluid whatsoever, half of the master cylinder is empty, half full...which part of the cylinder is for the front breaks and which is for the back? or is it split by sides? thanks
umm if your car is disk up front n drum out back the half closest to the firewall supplies the fluid for the front brakes, but if your not gettin any fluid its because u ran the front resevoir dry, which means u have to take the master cylinder off and bench bleed it now..
Old Jun 24, 2006 | 11:11 AM
umm ok explain this bench bleeding please lol
Fireslash
Apr 11, 2016 06:43 PM
jaridjohn
Oct 5, 2015 07:01 AM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
