9 bolt rotor removal..... suckers are ON!
Old Jun 22, 2006 | 08:24 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
well i'm doing the brakes on her 88 formula
i thought it was a 10 bolt rear, it's a 9'er
anyway
how the heck do the rotors come off?
i have them soaking with pb blaster
i tried hammering them, but broke the hammer
they just slid on/off?
it's got your typical rust on it
but i tried clearing it with a screwdriver
any tips?
Old Jun 22, 2006 | 11:17 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
Rust is a wench, they are just slid on. try hitting around the front of the hub, without hitting the hub itself or the studs. the "shock" may break them loose.
Old Jun 22, 2006 | 11:44 PM
net_coma's Avatar
I was not smart enough to think of this...another on the boards told me how to get one of mine off. I was able to get part of my camaro jack between the heavy (thick) part of the backing plate and the rotor. Slowly expand the jack and it will pop right off. Worked for him and worked for me. It really put no stress on the backing plate...was only able to catch a small part of the jack pad but poof...magic and it was off.
Good luck...I don't recall exactly how I positioned everything but it will work.
Old Jun 23, 2006 | 08:22 PM
Don 79 TA's Avatar
Engine: TPI
holly crap
got em off
had to soak em up good
then use some MAP gas on it to heat it
then used my smalled sledge hammper
finally broke off
what a chore
i also used the wire brush on it before and after to get any debri off
the new ones slid on
i used the raybestos drilled and slotted rotors
nice pieces
Old Jun 25, 2006 | 01:17 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
LOL, I had a shop do my last brake job, I also have the 9 bolt rear. They couldn't get one rotor off so they heated it with a torch and warped it. They had to replace that rotor on their dime.
I saw a guy doing brakes on a van and he soaked the back side of the rotor where it slips over the studs with anti-sieze when he was putting it back together.
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
