Weight of Ed Miller Willwood Kit
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I do not have my brakes were I can weigh them.
What is the weight of the following items
Willwood Calibers FBSL
Pads
Complete Assembled Modified Spindel with hub, Mounting Bracket, Bracket Bolts
C4 13 in x1.10 rotor
Adding the above weights to unsprung front weight calculations.
Pads
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Pads
Pads
Total kit is 45 lbs each side fully assembled with pads and brake lines installed but here's the breakdown:
Caliper: 5
Pads: 3
Rotor: 20-22 depending on maunfacturer, 25 for a Baer/DBA.
Ed
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
