lt1 ebrake trouble...
Old Jun 21, 2006 | 06:32 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
i went and got ebrake cables for a 92 bird wiht disk brakes and put them in on my lt1 rear end, and now one of them is tite and the other isnt tight at all so only one of the cables stays in the junction block where it hooks to the main cable to go up to the lever, i dont get it... but the cable on the drivers side is also tighter fitting then the cable on the pass side.
Old Jun 23, 2006 | 11:25 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Did you get the same part number? Sounds like you have one first design and one second design which are different lengths.
Ed
Old Jun 24, 2006 | 10:38 AM
Car: 91 formula
Transmission: t5
Ed
yea they both have the same tags on them wiht the same part number... ill have to get a picture up soon, its just been raining so freaking much that i cant get any pictures
Old Jun 24, 2006 | 10:11 PM
ebmiller88's Avatar
The distance from the bracket that holds the forward end of the cable to the cable backet on the calipers should be the same and therefore no difference in length, that's why I suspect different cables...regardless of the 4th gen rear. Take them off and lay them side by side and see what you get.
Ed
Old Aug 11, 2006 | 11:09 PM
TA josh's Avatar
i just bought an 88 GTA and i am having a simillar problem i first noticed the brake did not even engage so after looking the e brake looked seized after alot of loosening and messing with it it now will at least compress however no brake is engaged ? anyone know how to fix this??
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
L0tuS
Sep 4, 2015 11:16 PM
