Click in rear of the car when applying brakes
Old Jun 22, 2006 | 09:59 AM
ssjflint's Avatar
Car: 1988 IROC-Z
Engine: 350ci Tuned Port Injection
Axle/Gears: 2.77 Posi
I recently had my rear disc calipers in the back replaced about a month ago, now I've been noticing that there is a click in the rear of the car if i depress my brake pedal about halfway down, could this be related to the calipers or something different?
Old Jun 22, 2006 | 02:27 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
could be brake related...does the car shimmy in the rear at all during braking?
Old Jun 23, 2006 | 12:28 AM
ssjflint's Avatar
Car: 1988 IROC-Z
No, sometimes it seems the click is in different places though. Tonight it sounded like it was coming from the middle of the car, might be my transmission or something clicking. When I had my car fixed up they did alot of other things too, maybe I'm just a hypocondriac for my car and I'm looking for something wrong like I used to do with my Ford.
Old Jun 23, 2006 | 08:13 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
disc or drum in the rear?
Old Jun 29, 2006 | 09:10 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
I am having the same problem. sounds like a ticking or a metal to metal scratching noise that pulsates when braking. I have a disc rear. Does anyone think it could be from the e-brake pads?
Old Jun 30, 2006 | 12:01 AM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
might be a dry wheel-bearing ...
Old Jun 30, 2006 | 12:01 PM
ssjflint's Avatar
Car: 1988 IROC-Z
I think it actually stopped now, it hasn't done it in awhile. Sometimes it happened when making a left hand turn but I did some complex swerving and made it stop, maybe it was because my car was sitting over the weekend. I remember when I was little my dad would always complain that it sounds like his tires are hitting something when he turns, like they're rubbing up against the wheel-well or something. He was already having problems with the hood louvers rusting when the car was brand new, joy, I can't wait. I should probably just get the SS hood.
Old Jun 30, 2006 | 03:24 PM
Stevo's Avatar
Car: Pair of 92 Z28s
My rear brakes click when i come to a stop also...
Old Jun 30, 2006 | 04:07 PM
camaro05's Avatar
Car: 91 Z28
Maby Ed Miller can tell us what needs to be fixed/replaced.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
B_Dubya
Aug 26, 2015 05:09 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
