LS1 rear brake part #s
Old Jun 22, 2006 | 04:54 PM
patman_no3's Avatar
Car: 1989 Pontiac Trans Am
Engine: LB9 5.0L TPI
Transmission: T-56 6spd manual
Does anyone have a line on all of the GM part numbers for the 98+ LS1 rear brake upgrade? I keep finding conflicting part numbers, if I can ever find them at all. My main concern is the mount plates/backing plates, caliper abutments, brake line to caliper bolts, and any other miscellaneous pieces parts that will be necessary to complete the conversion. Any help would be appreciated.
Old Jun 22, 2006 | 08:04 PM
Poltergeist's Avatar
Car: 2002 Camaro SS / 1982 El Camino
Engine: LS1 / LT1 in the El
Transmission: A4 in both
From the LS1 Brake FAQ.
Part numbers
Old Jun 22, 2006 | 09:56 PM
patman_no3's Avatar
Thanks for the part numbers, but I'm still missing one, the backing plate/mount bracket that bolts to the rear axle tube. Like I said earlier, I found a part number, but it doesnt seem to exist to GM. Either way, thanks for the help.
Old Jun 22, 2006 | 10:54 PM
Backing plates:
LH 10434796
RH 10434797
gmpartsdirect.com doesn't list them for some reason. Might have to go to the dealer or call Dal to get them. Those parts numbers include the parking brake portion also.
Bolt 26059964
Nut 11515752
Old Jun 23, 2006 | 07:32 PM
patman_no3's Avatar
Thanks a lot, I really appreciate your help. You have definitley been much more help than the local dealer.
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Jan 19, 2016 12:21 PM
kyleb24
Aug 15, 2015 08:24 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
1nastygta
Aug 8, 2015 07:38 PM
