rear end swap..will these brakes work?
Old Jul 2, 2006 | 08:51 PM
fbodycustoms's Avatar
Car: which one? 92 rs, 89 z28, 89 formula
Engine: 3.1, 5.0, 355
Transmission: auto, 5-speed, 6-speed
im swapping a posi rearend from a 97 ws6 t/a into my 3rd gen fbody and it did not come with rear disk brakes...will my stock drums bolt up to the 4th gen rear or do i have to find a rear disk setup to make it work?
Old Jul 2, 2006 | 09:45 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
If the rear is a disc rear, please don't waste your time on swapping drums onto a disc rear, that's going backwards in performance. Just get yourself a set of rear LT1 brakes and go. You can find them on Ebay or from other vendors out there. If the rear is a drum rear, it's very easy to do a conversion on the drum rear and upgrade to much better brakes. I just happened to buy two complete LT1 disc setups this week so if you'd like one, send me a PM and we'll get you hooked up. I also have all new stuff if you'd like to go that way, I offer everything you'd need:
Yahoo! Photos - taramiller72's Photos - PBR rear brake kit
Ed
Old Jul 2, 2006 | 10:02 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I really think even trying the drum install would be a bit of work. I don't think you would have a way to mount the wheel cyl. unless you have a welder and alot of time on your hands.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
