need master cylinder?
Old Jul 3, 2006 | 05:01 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
I recently pulled the rear brakes off an LT1 Trans Am, and I'll be going back tomorrow for the fronts. I understand that I'll need to modify the rear axle flanges and install a proportioning valve, but I've seen a whole lot of contradictory evidence as to whether I'm gonna need to take the master cylinder from the LT1 car too. My '85 currently has a factory braking system with drum rears. Does anyone know what I can get away with?
Andrew
Old Jul 6, 2006 | 10:40 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
dude,
I've tried the LT1 master. It doesn't work with the brake lines our cars have between the master and the prop valve. I am running an 98&up F-body master, it has the same size lines and the same size and kind of fittings. The LT1 master has a smaller line for the rear I believe and the threads are different. I'm not saying the LS1 master is a direct bolt up you will have to coax your lines a little to make it work or bend up a new set like I did.
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
