Need help with master cylinder resevoir....
Old Jul 8, 2006 | 03:12 PM
bulletboy29's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
Is there an easy way to get the plastic reservoir off without breaking it? You just pry it off right? I can't get it to come off and it looks like it will break if I put to much pressure on it. Any help would be greatly appreciated!
Old Jul 8, 2006 | 08:41 PM
net_coma's Avatar
You did lift up on the clips before prying, yes.
Old Jul 8, 2006 | 08:56 PM
Car: '87 Camaro SC
Engine: 305 LG4
I got it off, but there weren't any clips. It was ON THERE! I can't believe it didn't break like the rest of the plastic parts on this car.
Old Jul 9, 2006 | 04:50 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
It should have 4 tabs on it to pull up on to pop it loose.
Old Jul 9, 2006 | 08:23 PM
Car: '87 Camaro SC
Engine: 305 LG4
I was removing the entire reservoir from the master cylinder to place on the new master cylinder.
Old Jul 9, 2006 | 08:30 PM
It has a roll pin that goes through it and the MC casting, between the 2 pieces of it where it plugs into the MC.
Never seen any clips, myself.
Old Jul 9, 2006 | 08:54 PM
Car: '87 Camaro SC
Engine: 305 LG4
All mine had was the rubber seals holding it on. Maybe they changed them on certain years. It was on there so tight that I thought there was some sort of clip or pin that I couldn't see. I rocked it back and forth while prying with a large screw driver and it popped off. It was PITA!
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
