Proportioning Valve issue...
Old Aug 2, 2006 | 09:37 PM
black_highway's Avatar
Car: 91' RS Camaro
Engine: 305c.d. Toilet Bowl Injection
Hey guys, i'm having a bit of an issue. I had to take my car to the shop today to have the brakes properly bled, so i figured, what the hell, and i had them install the 1LE prop valve i had laying around. Turns it it doesn't fit. My car is a 91' RS, and the prop valve i have is 140899496. The tech said the threads were different and that it would not fit. Does anyone have any knowlege about this issue, and what the proper valve would be? Thanks.
Old Aug 3, 2006 | 06:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This from Dan Burke.
1LE Combo Valve (proportioning valve)
14089496 1989 1st design: M1.0 tube nut threads (For 1982 - early 1989 applications)
10136840 1989 2nd design: M1.5 tube nut threads (Late 1989)
10136840 1990-'92: M1.5 tube nut threads.
JamesC
Old Sep 16, 2006 | 10:54 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Is the 10136840 the GM P/N? I am planning for a big brake upgrade for my car, and want to have all the parts lined up. Thanks!
Old Sep 22, 2006 | 03:33 AM
Eightyninef's Avatar
my car is may 89, and the late 89 valve did not fit. so take that information with a grain of salt.
I finally installed the early 1LE valve, and the only difference is A LOT MORE REAR BIAS.
BE CAREFULL IN THE RAIN !!!!
Old Sep 23, 2006 | 01:15 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Don't mean to hijack, but I think this issue correlates to the original poster's problem. I have a J65 car that will have the PBRs again like it should. I have the "FX" master which, according to ebmiller, is the 1LE MC. OK, I have a 1LE/drum master on a J65 car, is there ANY way to tell the difference between the 1LE/J65 (same thing according to this: https://www.thirdgen.org/forums/brak...t&pagenumber=3)
and the other props? I ask b/c I'm not sure if the prop was swapped too; I also have another prop which came with the 89/10-bolt/PBR brakes I won from ebay...sooo...I'd like not to buy a third prop valve unless they both are wrong.
Eric
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
