Rusty bleeder?
Old Aug 26, 2006 | 10:31 AM
jmillar`'s Avatar
Rusty bleeder?
Anyone have any solutions for what to do with a caliper or wheel cylinder where you know it needs bled, but you can't get the bleeder out, rusted securely in place and rounded off?
I know you're thinking penetrating lubricant, vice grips etc. All that fails, what can you do to bleed them? Just working on the assumption that they truly can not be bled through the bleeder screw.
I came up with the idea of using a vacuum pump hooked up so that you bubble the air through fluid as you pump it out, but when you let off the vacuum the fluid is sucked back in. However, the guy I was working with is convinced it won't work because the pisons don't seal tightly to the cylinder without pressure.
Obviously this isn't third-gen specific, but I did encounter it on a thirdgen so that's close enough
Old Aug 26, 2006 | 10:33 AM
j dezzy's Avatar
Car: 87 TA
you could bleed them through the master cylinder.
Old Aug 26, 2006 | 11:46 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Replace the caliper.
Old Aug 27, 2006 | 05:56 AM
B Rhodes's Avatar
Car: 91 B4C
You can try lightly heating them with a propane torch, oxy/acetelene is too hot but if your careful a small propane torch can work without melting the seals inside..... next step replacement
Old Aug 27, 2006 | 10:19 AM
jmillar`'s Avatar
j dezzy, I don't know how you mean.
Apeiron, I know that's the normal answer, my point is, is there any way to avoid that? especially on drums where there's more of work to r&r the wheel cylinder, compared with a caliper.
B Rhrodes, how does heating help? Force air out via expansion, or something like that?
Old Aug 27, 2006 | 11:45 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Heating it with a torch might help you get the bleeder free. There's no way to bleed it without opening the bleeder.
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
aaron7
Sep 30, 2015 09:15 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
84redta
Sep 19, 2015 09:58 AM
