Rear drums knocking while using the pedal
Old Sep 9, 2006 | 03:59 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Enough said really...while slowing down (e.i. using my brakes) the rear drums knock. The knock gets slower as the car slows down and stops when the car stops. Sound also stops when I release the pedal. The brakes are also really creaky (NOT squealing) and make a rusty sounding crunch noise sometimes when they get fully depressed as the car is coming to a stop. What can I do in the meantime before ai DITCH these things?!
Old Sep 9, 2006 | 04:20 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
I had a set of drums that knocked.. turned out to be warped drums.... the crunching and such could be the springs....pehaps...
Old Sep 9, 2006 | 04:36 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
It does sound like spring noise. What can I use for lube?
Old Sep 9, 2006 | 04:21 PM
if the springs are really making a crunching sound I would just replace them. it really is not that expensive.. and t will keep any oil or other contminates from getting on the pads. I think i have rebuilt both drums on mine. including the cylinders, and it did not cost my that muck, and it improved the brakeing a bit.
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
