Coil spring compressor - 1984 TA ???
Old Sep 23, 2006 | 05:41 PM
Guest
Guest
Posts: n/a
Hi,
Please tell me what kind of spring comressor I should use
for the front coil springs. I have an 1984 Firebird Trans Am.
I am beginner, I never lowered a car until now.
I have a compressor but I had to make it shorter because it was
too long. And the problem is now that there is not enough space
around the spring to place this compressor. I can only place
one compressor on the side near to the brake disc. But on the other side
(near to engine) I can not place any compressor. Or the compressor
should be put inside the spring through the hole in the control arm?
I could not compress the spring with this one compressor placed outside, the spring still pressed the control arm very much.
Please tell me which compressor I should use and please send me
pictures about how it looks and if it is necessary please explain me
how I should use it. Thank you very much.
Regards,
Laszlo
Old Sep 23, 2006 | 06:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you need to get the compressor that fits up inside the coil spring
Old Sep 23, 2006 | 08:22 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Read through this how-to:
Yahoo! Photos - taramiller72's Photos - 88 Camaro Rebuild
Ed
Old Sep 24, 2006 | 02:33 AM
Guest
Guest
Posts: n/a
Hi,
Thank you! It helped me very much!
Laszlo
Old Sep 24, 2006 | 02:36 AM
Guest
Guest
Posts: n/a
Hi,
Do you know where could I buy such a compressor?
In Europe would be good...
Thank you,
Laszlo
Old Sep 24, 2006 | 03:55 PM
ebmiller88's Avatar
Oh crap, I didn't see your location so I'm not sure how you'd go about getting one over there..maybe a repair shop can rent you one?
Ed
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
morrow
Jan 13, 2024 12:29 PM
Stryker412
Sep 7, 2015 09:11 AM
FormulasOnly
Sep 6, 2015 10:42 AM
mrdevontay
Sep 2, 2015 08:04 PM
