LS1 master cylinder on a third gen brake booster?
Old Sep 25, 2006 | 02:18 PM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
'88 GTA
From searching, I've determined that an LS1 master cylinder should be pretty much a direct bolt-in for my car. However, I can't find anything on the booster.
Will the LS1 master cylinder fit a third gen brake booster? From what I can tell, the bolt centers don't look any different.
Old Sep 25, 2006 | 09:01 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Bolts right up. One of the outputs (front I think) is a slightly different pitch, but mine threaded in fine and doesn't leak.
Kevin D.
Old Sep 25, 2006 | 09:29 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Is there some benefit to doing this ?
Old Sep 26, 2006 | 04:29 AM
redrummer's Avatar
Engine: 5.7L L98
I don't know about any benefit. I just want it for the screw on reservoir cap. With the stock flat capped one that came on third gens, I can't get a good enough seal to pressure bleed my system.
I can only get 10psi out of it before the cap itself leaks or the grommets between the cap and cylinder start leaking. The service manual says to bleed it at about 20psi.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
