82 camaro brakes?
Old Oct 6, 2006 | 09:43 AM
outlawracer's Avatar
Car: 82 camaro berlinetta/87 sport coupe
Engine: 87 LG4 305
Transmission: world 5speed
82 camaro brakes?
Hey guys I have a question about my brakes. I have all new brakes on my 82 Camaro berlinetta the only thing that not new is the brake booster and the master cylinder. Well every time I hit the brake threes a ton of travel before I start stopping. Is it because my brakes suck *** ***** or is something wrong?, thanks guys
Old Oct 6, 2006 | 03:35 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
first thing is to make sure there is no air in the system by bleeding it.
when you are sure you have no air in it, check the adjustment on the rear brakes, too loose will cause a low petal, too tight will cause the rear brakes to drag & overheat the shoes.
Old Oct 6, 2006 | 03:59 PM
Engine: 87 LG4 305
well as far as i know theres no air in there, the rear brakes may need a littel adjustment. as i said almost everything is brand new
Old Oct 6, 2006 | 05:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
if you've got a lot of travel in the pedal, 95% of the time it's due to air in the system. A $6 bottle of brake fluid to completely flush the system will take this out of the equation, if it's not the problem (but i'm guessing it is).
Just put a bottle of brake fluid, upside down, in your reservoir, and open your bleeder screws, gravity flush it for a while. Or If you want, you can do the whole "open, pump, close, release" etc style of bleeding.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
