4th Gen Rear Brake Swap
Old Oct 20, 2006 | 05:59 AM
BlackRabbitZ28's Avatar
Car: 1991 Z28 5-Speed
Engine: 305TPI
Transmission: 5-Speed T-5
I have drum on the rear of my car and I hate drum. For everything, maintenance, quality, looks, I just dont like them at all. I want to do a complete swap to disc. I found the right up on here and I'm pretty sure I can do it. I was at the junk yard and I found a 93-96 camaro with the breaks I want. The guy said he'd give me the entire rear end with brakes and everything for $150.
That seemed like a pretty good deal to me. My first thought was just swap rear end. Then I was like duh, I have the G92 package with a 5-speed so I have .345 gears. Should I pick it up anyways and just swap all the componnents over? Or should I swap rear ends and swap gears? What kind of problems would U run into if I did that? If I even consider swapping rear ends am I just causing more work for myself in the long run?
Old Oct 21, 2006 | 02:06 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Is your current rear a 9 or 10 bolt? The brakes will install perfectly but you will need a 9 bolt compatible backing plate.
Nice ride, BTW.
Ed
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kyleb24
Aug 15, 2015 08:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
