weird???
Old Nov 1, 2006 | 10:43 AM
19Irocz86's Avatar
Car: 1986 Iroc z z28
Engine: 305 tpi
weird???
well i was driving the otherday and my passenger side rear drum was making a strange noise so i parked it at home, then i took it back out and as i was pulling out the driveway the rear tire locked up for a second or two when i applied the brakes. so i got out and noticed i was missing a lugnut, then i pulled the wheel off and the drum and seen that a rear pad was explodied and these pads are new with only 3000 miles at the most. what will cause a pad to explode, can it be the missing of a lugnut?? also just one is exploded the other is fine??
Old Nov 1, 2006 | 08:36 PM
19Irocz86's Avatar
Engine: 305 tpi
anyone??? i need help
Old Nov 1, 2006 | 10:08 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
maybe it just got hot, maybe they werent' adjusted right. Check to see that the drum is OK, replace the shoe, and get motoring.
Ed
Old Nov 1, 2006 | 10:14 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Were they bonded type pads with no rivets to hold them to the shoe ? If so you could have gotten a bad one and it let loose and kinda got ground up in there.
Old Nov 1, 2006 | 10:17 PM
19Irocz86's Avatar
Engine: 305 tpi
i bet ur right miller now that i think about it i didnt focus hard on the adjustment and i just paid for it, jet, these pads do have rivets in them holding them on the shoe
another question should i usa ac delco pads? or a aftermarket brand???
F-body-fan
May 4, 2026 09:42 AM
db057
Jan 10, 2020 08:55 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
BWilcox
Sep 20, 2015 12:19 PM
