brake problems
Old Nov 5, 2006 | 05:12 PM
strangladesh's Avatar
brake problems
I just finished up re-building the rear brakes on my 82 z28, the problem in the bigging was it pulling really hard to one side and upon romveing the drum i notice one wheel cylender was side ways almost pointing up, well i think the backing plate was rusted out so i replaced some stuff....
new lines from the split in the center of the rear end, new backing plate on one side new wheel cylenders on both sides, and then shoes and hard wear...
I get a firm brake pedal when the cars off but when i start it gets all soft and brake light comes on.
Old Nov 7, 2006 | 04:46 PM
no one can help me? how should i go about checking the brake system to find out whats wrong?
Old Nov 7, 2006 | 04:58 PM
Wheel Spin's Avatar
Car: 89 Formula 350 (x 2)
Axle/Gears: BW 3.27
Bleed the brakes?
Got fluid?
Master cylinder get air in it? (even once?)
Old Nov 7, 2006 | 07:55 PM
Will i have to bleed the brakes while the cars on or off? We did it with it off but it didn't seem to help
Old Nov 7, 2006 | 08:43 PM
Wheel Spin's Avatar
Axle/Gears: BW 3.27
No, it doesn't need to be running. Sounds like you got air in the master cylinder, that's why your'e getting the brake light. You will need to "bench" bleed the MC first, then the rest of the system. Do a search, it was addressed here recently. And buy a book, they come in handy.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
overdriv
Aug 20, 2015 03:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
