Which backing plates do I need?
Old Nov 7, 2006 | 12:00 AM
C&DPerformance's Avatar
Car: 89 Formula 350
Engine: 355
I have a 89 formula with a borg warner rear and pbr brakes. I have a 10 bolt housing from a 88 formula that is disc. Which backing plates do I need to swap the pbr calipers from the 9 bolt to the 10 bolt?
Old Nov 7, 2006 | 05:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You require the ten-bolt backing plate (the nine-bolt has a different bolt pattern and won't fit the ten-bolt axel flanges). You can see the difference in the following link:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Nov 7, 2006 | 07:36 AM
simz28's Avatar
Car: 92 z28, 07 Silverado
Engine: LS1, 5.3
Axle/Gears: 3.73, 3.23
i had this same problem. I just drilled new holes in the backing plates and everything turned out fine.
Old Nov 7, 2006 | 01:42 PM
JamesC's Avatar
I believe a few members have done the above, but with the plates readily available, the best solution, at least IMO, is to purchase new.
JamesC
Fronzizzle
Mar 18, 2019 08:29 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
