Emergency brake recall disc brakes!
Old Nov 13, 2006 | 10:38 AM
5speed's Avatar
Car: 86 IROC
Transmission: 5 speed
Axle/Gears: limited slip
My local dealership ordered the parts last week to complete this recall on my car.
86 IROC with rear disc brakes.
I thought I was going to have a real fight to get it done but the service manager looked after me.
I've owned it for 4 years and the e brake has never worked right. It will be comforting to know I can park on a hill and not worry about the car jumping out of gear and disappearing..
Old Nov 13, 2006 | 11:47 AM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
whats the recall? i just happen to have an 86 with disc rears
Old Nov 13, 2006 | 02:44 PM
5speed's Avatar
Car: 86 IROC
There is a problem with the adjusters not functioning on the calipers. They will fix standard transmission cars but not auto's..
from f-body.org.
A technical service bulletin described this for early-mid '80s rear disk brakes. It seems that the rear disks in these cars would be adjusted by applying the emergency brake. When you pull the emergency brake lever up, the lever turns this little device called an actuator screw. This little screw type device is also on a ratchet, so that pulling the e-brake up, turns the screw. But letting go allows the ratchet part to function and set the pads at that time. So, using the emergency brake is mandatory for maintaining the rear disk setting on early model rear disk units.
But, here's the problem with them. There's a little spring on the actuator screw assembly that allows the pads to back-off from the disk a little bit before the ratchet mechanism is engaged. This must be done, otherwise full brake pressure would be left on the pads when the e-brake is released. Well, that little return spring K-factor was not correctly chosen from the factory, and the result is that the ratchet NEVER functions after the actuator screw gets a little dirty. Hence, the pads simply work their way out all the way when the e-brake is used. Using the e-brake all the time seems to keep the actuator free for a longer period of time, but even with the correct spring weight and screw, the e-brake is required to adjust the parking brake actuator.
The TSB states that cars with a manual tranny are eligible for a free fix as the e-brake is required to park the car, but the auto is not eligible. Why? Only GM knows. However, fixing it yourself should be relatively easy. The rear wheels are removed, and there is a nut on the back side of the brake caliper that holds the parking brake lever. Remove the nut, lever, and soft grommets. Put a large washer over the shaft to act as a spacer, and then put a wrench on the hex of the shaft, and tie it down with the nut. Turn the wrench to back the brakes off. After a while, this will over travel, as if there was a one way clutch. Tighten the shaft to see where the hex is when the pads are tight agains the rotor. If it is in a spot that the parking brake lever will fit, and turn about 1/3 of its travel to tighten apply the brake, then it is good. If not, try again.
This will remove some of the brake pedal slop also. It's supposed to be self-adjusting (apply parking brake thirty times), but it is common for it not to work.
Make : CHEVROLET Model : CAMARO Year : 1986
Manufacturer : GENERAL MOTORS CORP.
NHTSA CAMPAIGN ID Number : 91V055000 Recall Date : MAR 13, 1991
Component: PARKING BRAKE:CONVENTIONAL
Potential Number Of Units Affected : 179036
http://199.79.180.162/prepos/files/A...-91V055-NN.PDF
dbrochard
Sep 19, 2015 08:13 PM
Numbah-1
Sep 12, 2015 08:57 PM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
