Chevy and there INFINATE WISDOM *lack there of*
Old Nov 17, 2006 | 09:55 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
So I start doing a brake job on my car..
WHY THE **** DID CHEVY USE STRIPABLE HEX BOLTS TO HOLD THE CALIPERS ON..
D:
I really dont know what to do now, I cant get the ****** ****** free.
Yeah, im in that "throw wrenches at everything and swear like a sailor* mind set.
PB blaster didnt work, so I have the hex wrench in the bolt, and im hammering it lightly trying to break it free, ended up stripping the bolt. Im at a total loss, does this mean I get to go on a wonderfull journey to the junkyard and find a new caliper/caliper holding stupid thing?
Old Nov 17, 2006 | 10:07 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Using the right size wrench?
If so, time for the welder.....
Old Nov 17, 2006 | 10:10 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Aye, I was using the right size wrench. Ive never done the brakes on my car before, I think the previous owners may have caused the preliminary damage.
Ive got a welder at my shop, what should I do? Weld a nut onto it or something?
Old Nov 17, 2006 | 10:20 PM
Lo-tec's Avatar
Or place a bolt in the hex-head hole and weld that. The heat will loosen up the caliper bolt you're about to replace (and maybe the seals in the caliper) and help it come out.
Old Nov 17, 2006 | 10:42 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
=] thanks, monday I should be able to access the welder. I pretty much figured this is what I was going to have to do, but I really needed to vent. Thanks =]
Old Nov 22, 2006 | 05:15 PM
JDud's Avatar
If you have room, you can try to use a bolt extractor...
http://www.irwin.com/irwin/consumer/...e/11117_lg.jpg
As they are reverse threaded, while you try to thread them into the stripped bolt in the counter clockwise direction, it will increasingly be trying to rotate the bolt out of its hole.
They have helped me out more than once...
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
z28venezuela
Oct 24, 2015 08:15 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
