Practicality of replacing my brake booster?
Old Nov 19, 2006 | 06:35 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
So I am restoring the car, putting a new engine in, the works basically. I have just about everything out of the engine bay/firewall, including the booster.
My question is, how often do these go bad? It's off now, is it worth replacing? I've always felt my brakes were so so, even with the 4wdb setup with pbr's out back. The car would ease to a stop under heavy pedal and then lock. Never set the car down well at all. So I am thinking since I am putting upgraded brakes all around, lines, rotors, master, prop, that I might as well replace the booster too>!?!?!
What do you guys think? Thanks fellas
Will
Old Nov 20, 2006 | 08:54 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
If cash is not an issue and its already off get a new one. The booster only helps you apply the service brakes, and has nothing to do with how the other parts perform.
Vintageracer
Jan 10, 2020 05:33 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
