big brake hub question
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I am looking at doing the machine work myself and I cannot find the directions for the size the finished hub/rotor needs to be. Can somebody point me in the right direction?
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You need it just small enough to drop into the rotor. I cut mine differently for some kits...which one are you going with?
Ed
Ed
Engine: LT1; LT1
I really want to go with the ZO6 but I will most likely ge the LS1 setup due to its stong over the counter availability. Also, I am looking at building a kit for an 81 Camaro. I am doing a total front clip restoration and now is the perfect time to do the measuring and fitting. I know you are really good at these brake kits, would you be willing to help out with this project? I have access to the spare parts and machine work but I would like to have and "expert" to double check my measurements and make sure the system will function properly.
Let me know.
Let me know.
Glad to help. A good measurement for LS1s is 5.9" but not much less.
For your '81, have you gone to www.nastyz28.com ? Lots of 2nd gen info there, I'm slowly working on a '70 as well.
Ed
Ed
Engine: LT1; LT1
Ed
Ed
