replaced brakes, brake pedel does not feel right
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
ok here is the deal , i replaced the front brakes cause pads where worn, now i notice driving around the pedel is going to the floor sometimes and feels as if i need to pump them once before coming to a stop... but as i compress the pedel i can feel the pads grabing and working it just seems as if i need more pressure in the pedel.... what should i check frist ? or what could this bee??i check fluid it could be old how offten should i replace the fluid ???
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
You had good pedal before replacing the pads? Sounds like air has been introduced into the system or you have a leak. Are you loosing fluid? Did you open the bleeder valves? Did you compress the caliper cups when you installed the pads? Might possibly have damaged a caliper seal?
Back to basics. Check for leaks and go back over the componets that you touched. Bleed the system if no fluid leaks are found.
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Check the things Wade said first.
Did you use ceramic pads by any chance? Those things take a while to seat/match the rotor. I almost rear ended a cop when I put the ceramics on my '92 - they really made the braking feel funny for a couple of days but are fine now.
it the caliber seal round by chance ???
