Need help with Brake Upgrade!
Old Dec 30, 2006 | 06:46 AM
PeterFeix's Avatar
Car: Trans AM GTA 1989
Engine: 383 HSR AFR195 JRC Cam280/286
Transmission: T56 Conversion
Axle/Gears: 3.27 9bolt
Hi!
I have some serious problems with my brake system.
First of all:
1988 T/A 5.7 Disc+Drum Setup
Front Discs: Raybestos PG+
Pads: Raybestos Brutestop
Drums: Raybestos ( ?? )
I changed my brake fluid some weeks ago, new brake lines, new drums with pads + cylinders.
Front Brakes are about 1 year old.
The brake performance is sooo bad, the brakes/wheels block almost immediately.
So I want to upgrade my brakes to better ones.
At summit i've seen those stainless steel front disc upgrade kits [ SSB-A2350003 ]. Worthless? Good deal??
Or should I go with PowerStop crossdrilled rotos & hawk pads?
Hope you can help me, my german F-Body buddies couldn't! (most of them use raybestos or original replacement stuff)
Last edited by PeterFeix; Dec 30, 2006 at 06:53 AM. Reason: pressed on send, post was not completed yet
Old Dec 30, 2006 | 08:26 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
For a little more than those calipers check this out. If you've at least 16" rims that is.
Big Brake Upgrade Kit:
http://www.metzcon.com/bigbrake/
I just ordered a Premium Kit and I'm just waiting to have them delivered.
Billy Decker
Sep 4, 2015 03:46 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
