Those using 1408 9496 1LE PROP VALVE
Old Jan 3, 2007 | 03:36 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
This is the 82-early 89 version FYI. It looks like gmpartdirect is the way to go by the way. About 72 dollars shipped to me.
Anyway a lot of threads have been devoted to this.
Many people saying GM finally got it right with the late 89-up version because this was the only one for all F-bodys starting 90. So I know a few of you have used the late 89 up version with success.
What about this 82-early 89 version 14089496...anyone noticed a difference ? I mean I hope it has the better proporioning that the late 89 up version supposedly has ?
Thx for patience and replies.
Old Jan 4, 2007 | 04:43 PM
Jetmeck's Avatar
anybody ?
Old Jan 4, 2007 | 07:53 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i had it on my LS1 setup. never had anything else on there to compare it with, but it worked good
Old Jan 4, 2007 | 08:38 PM
anthony64ss's Avatar
Car: 1984 Z28
Engine: L31
Transmission: WC T5
Axle/Gears: 10 bolt 3.73
I dont think the valving is different between the two. My understanding is that pre mid 89 used a course pitch fitting(M 1.0?) at the inlet of the prop valve, while mid 89 on used a finer pitch fitting (M 1.5 or 1.25 cant remember). My 14089496 works great on my 85 with stock fronts and 1le rears. I did have to bend one line, however, no biggle.
Old Jan 4, 2007 | 10:06 PM
Jetmeck's Avatar
What year car and are you sure you had the 82-early 89 version...14089496 ? Thx
Old Jan 5, 2007 | 05:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I believe the brake lines were changed mid-89 from M1.0 to M1.5 flare threads. The M1.0 lines are the first design and the M1.5 lines are the second. I used 14089496 for my front 1LE conversion and later for the 1LE rears. Mine was a direct fit.
JamesC
Old Jan 5, 2007 | 12:24 PM
Jetmeck's Avatar
That is what I am interested in ? Anybody verify this ?
I undertstand the thread pitch was different. Thx
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Necron
Brakes
Sep 14, 2015 12:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
