Rear Proportioning Valve???
Old Jan 4, 2007 | 07:14 PM
CamaroMayo's Avatar
Car: 1983 Camaro Z-28
Engine: 305 w/ Carb
Transmission: B&M Turbo 350
Axle/Gears: Stock W/ Rear Disc
Hey guys im new to the board and had a couple questions. i have a 83 z28 and i out a 84 rear end with disc brakes on it, but i need the Rubber line and proportioning valve, (witch splits into right and left brake line on rearend) and i cant find it anywhere.. is there a site that would sell them or anything aftermaket that would work??? anyone have any ideas for have an extra hanging around?
Old Jan 4, 2007 | 10:10 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
The hoses could be gotten at any parts store. Someone will surely know if the 83 had disc brakes ? which I am sure it did. I doubt the 83 to 84 is different part numbers anyway. You can check this out at the local NAPA or whatever , while there simply ask about the DISTRIBUTION block you need to separate the lines, they might have this also.
If you meant the hard metal lines you'll probebaly have to bend your won and flare unless you want to spend big bucks there a few places on the net that will supply pre bent lines.
Old Jan 5, 2007 | 05:38 AM
CamaroMayo's Avatar
Engine: 305 w/ Carb
Allright ill head over to the parts store after work and see what i cant come up with. the dealer said the part was discontinued. well see. thanks for the help.
Old Jan 7, 2007 | 05:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might consider the "Parts Wanted" in the classified section of this site. It's an invaluable tool.
JamesC
Old Jan 7, 2007 | 02:53 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
I just got a rear disc rear end, and I am going to have to get a prop valve..The guy at the junkyard wanted 20 dollars for it, did I screw up by not getting it??? I thought you could get tem at the auto parts.....
Old Jan 8, 2007 | 05:33 AM
JamesC's Avatar
Probably. IIRC, GM still has them--at considerably more than $20.
JamesC
Old Jan 8, 2007 | 10:40 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
The distribution block and the proportioning valve are still available from GM. The cost for the distribution block and rubber line isnt too bad but, the (disk brake) proportioning valve runs about $100+. As far as I can tell, there isnt much visual difference between the drum / disc proportioning valves so, exercise great care if purchasing it from a used source. Given a choice I'd put out the money for factory new parts.
1992 Trans Am
May 10, 2023 07:19 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
