2000 camaro front brakes
Old Jan 9, 2007 | 08:26 AM
ls2twntur1200hp's Avatar
Car: 1988 Firebird Formula
Engine: 5.2 tpi
Transmission: th700r4- TCI
Axle/Gears: fourth gen rear 3.42
Has anybody ever done the swap to ls1 brakes up front. What i was going to do was take the stock rotors, machine the rotor off and then machine what is left of the hub down to the proper size. and the drill and tap holes in the spindal for the caliper braket. Also i want to use the whell speed sensor because i'm going to TRY to to an abs retrofit. Any advice before i start?
Old Jan 9, 2007 | 09:12 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Check out this site.
http://www.metzcon.com/bigbrake/
Old Jan 9, 2007 | 09:33 AM
Engine: 5.2 tpi
Thanks for the website- Big Help!
Old Jan 9, 2007 | 11:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
https://www.thirdgen.org/forums/faq-...s1-brakes.html
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
