Bendix Titanium brake pad questions
Old Jan 27, 2007 | 05:25 PM
MIDNITERIDER's Avatar
Car: 1988 Formula 350
Transmission: 700R
Axle/Gears: 9 Bolt...3:27
I have a 1988 Formula 350 with the WS6 pkg. 4 wheel discs (9 bolt rear). I would like to install the Bendix Titanium pads MKD154 but can only find the fronts.
My question is for the rear discs...do they make them(part no.???) or are the fronts compatable to the rears????
Any help in this matter is appreciated.
Old Jan 27, 2007 | 08:34 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Front and Rears are diffferent. You will need to search a little more or soneone has a p/n for you. I use PF z-rated pads and the 89 & later 9-bolt PBR rears are expensive vs the fronts.
Old Jan 31, 2007 | 03:54 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Wow, I dunno about yout Bird, but on my 88 IROC with J65 brakes, the front and rear use the same pads. MKD154. In fact, I just bought 2 sets, for fronts and rears, along with 4 new rotors and some Earl's lines and solobleeds to put on. If you have the iron single piston calipers on the rear (like I do), then you wilkl also use the same pads on the rear.
Old Jan 31, 2007 | 07:14 AM
Transmission: 700R
Thanks for the reply.......Yes I have the J 65 code and doing the search I finally ran into the "RIGHT" word combo and found your posts along with Chickenman35 posts on this subject BUT not till after I ordered MKD154 for the front and the D154 for the rear(per Lordco rep)....will try them out this summer when Bird is back on the road from storage but will order another set of MKD154 for the rear. I should have been more patient but the Bird is a "keeper"(Im the original owner).
Old Feb 1, 2007 | 12:38 AM
Tremo's Avatar
Return the D154s with some cash in exchange for the MKDs.
The 154 should have keyed you off that they're the same pads.
Old Feb 1, 2007 | 06:41 AM
Transmission: 700R
Unfortunately not practical for me..live in Ontario Canada..15 minutes from Niagara Falls and my son bought them for me where he lives Vancouver B.C.
Checked around here and no one carries the Bendix line anymore so they are on their way now.
Old Feb 1, 2007 | 04:30 PM
Tremo's Avatar
Drive across the border and find a Kragens/Checkers/Shucks and buy them there.
I've been to Niagra Falls. The Canadian side is very nice. American side sux.
Old Feb 1, 2007 | 05:09 PM
Transmission: 700R
Thanks for the heads up...will check it out...
Old Feb 1, 2007 | 07:14 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I was able to get them in Toronto.
I've been using them for a couple years and my car sees a lot of track days at mosport - I find them to be a pretty good pad for what they are.
Old Feb 2, 2007 | 06:18 AM
Transmission: 700R
I've been using them for a couple years and my car sees a lot of track days at mosport - I find them to be a pretty pad for what they are.
Where in TO....?????
Old Feb 4, 2007 | 02:45 PM
Tremo's Avatar
Wow, the Bendix TiMets are a huge improvement! Well worth the cost.
Well, to be honest I also put on all new rotors at the same time. Raybestos. BruteStops in the front, PG-Plus in the back.
Old Mar 11, 2007 | 06:56 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Where
in TO....?????
Seems these guys have them:
http://www.brakes.homestead.com/
I got a couple of sets from another place in the west end but I can't find the invoice; if it surfaces when I do my taxes I'll post the name.
Old Mar 11, 2007 | 07:47 PM
Transmission: 700R
Thanks!!!Had to get them from Lordco in B.C.(my son lives there) but would like a closer dealer..
Old Mar 11, 2007 | 07:55 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Also Advance auto parts carries them too. Either way, I have them on my car..Youll like them
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
kyleb24
Aug 15, 2015 08:24 AM
Zachattack0925
Aug 12, 2015 09:52 PM
