no back brakes
Old Jan 29, 2007 | 03:43 PM
adam86's Avatar
Car: 1989 GTA
Transmission: Stock 700r4
Axle/Gears: 3.08 POSI
no back brakes
hey guys my back brakes are completly shot and im currently only using the front brakes to stop... the rear brake also leaks fluid when i stop hard and fast.
could this cause damage to my front brakes?
the brake has alot of play in it compared to other cars i've driven but has no air in the lines.
Old Jan 29, 2007 | 03:52 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
hate to break it to you, but if you have a leaking hose, you have air in the lines. I would just fix it. I can't see it damaging anything, except causing more stress and wear on the front brakes and suspension, but you should fix it ASAP for the sake of safety.
Old Jan 29, 2007 | 06:35 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
fix the leak problem, and bleed the system out
adjust the rear shoes out manually-
check the adjusters- make sure they arent frozen in which they are commonly-
if so then buy new ones at a parts store
may need new shoes while youre at it, also inexpensive
if the leak is coming from inside the drums then you have a blonw wheel cylinder- also inexpensive and will require new shoes and may also require a length of 3/16" steel tubing in case the line fitting is too rusted and wont come off without jut cutting the line instead of removing it from the W/C in which is also a common problem especially in the salt rust belt
this is all routine maintainence and for safetys sake
good luck
Old Jan 29, 2007 | 08:13 PM
adam86's Avatar
Car: 1989 GTA
it must be the wheel cylinder.. it leaks from the brake itself not the line.
would this cause the weak peddle?
Old Jan 29, 2007 | 08:54 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
Leaks will cause a weak pedal.
sailtexas186548
Jan 19, 2016 12:21 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
