ls1 front brake question
Old Feb 11, 2007 | 10:54 AM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
I havn't been able to find a direct answer on here, so I'll ask: with a c5 rotor and c5 adapter brackets, can I use ls1 caliper and ls1 caliper bracket?
Old Feb 11, 2007 | 11:19 AM
simz28's Avatar
Car: 92 z28, 07 Silverado
Engine: LS1, 5.3
Axle/Gears: 3.73, 3.23
The only part from the ls1 caliper assembly that you can use is the caliper, you need to use a c5 bracket and put the caliper on that, unless you make a custom adapter bracket
Old Feb 11, 2007 | 11:29 AM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
That's what I needed to know. Thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
redmaroz
Aug 16, 2015 11:40 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
