brake dust.....
Old Feb 14, 2007 | 08:15 PM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
Transmission: Swapped in T5
brake dust.....
has been a major issue to my car, im talking from cleaning the wheels and after a full day of driving having my front wheels look like they are painted black. what causes so much break dust? i know its an older car so its going to happen but ive had other older cars with alot less break dust than this one, what can i do to stop the brake dust? would be upgrading to a larger brake setup get rid of the problem? let me know. thanks.
Old Feb 14, 2007 | 10:31 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
get differant brake pads. the pads are the problem.
Old Feb 14, 2007 | 10:45 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
the pads are where most of the dust comes from, a very small amount comes from rotor wear.
you can try changing to a higher quality pad which should help, think something carbon metallic.
i use the Wagner SX series pads on my car & i have very little dust.
the carbon metallic pads don't stop as well as standard pads do when cold, but they do work better when hot.
carbon metallic pads aren't cheap, depending on if you get a discount & how much it is where you buy from, expect to pay anywhere from $60.00 to 120.00 for for a set.
a side benefit of carbon metallic is longer life, with the Wagner MX pads i was getting around 12~15,000 miles out of them, with the SX pads i get around 50~60,000.
of course the harder you are on your brakes, the more they wear & the most dust you get.
Old Feb 14, 2007 | 10:54 PM
dustpusher's Avatar
Car: 88 IROC-Z
I have had good luck with ceramic pads.Dont know if they are as good as semi metalic but very little brake dust.
Old Feb 15, 2007 | 07:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the problem is as stated, service station brake pads...
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
