Using 9 bolt adapter plates on a 10 bolt
Car: 84 TA Black/ Gold
Engine: 383 With Vortec Heads
Transmission: 700 R4 Lvl2 Performabuilt 9.5 Vert
Axle/Gears: Moser 9" with 3.70
I have been reading for days and i can't seem to find the post. I thought i read somewhere of someone elongating the holes or something.Has anyone used 9 bolt adapter plates with pbr calipers and modifyied them to install the disc brakes on a 10 bolt. Was it successful and safe. Thanks for any info
The answer depends on what backing plates you're starting out with.
If you have 9-bolt PBR backing plates, then you probably can mount them onto a 10-bolt with a minimum of effort. It's a little more hassle putting 10-bolt ones on a 9-bolt because the axle tube diameter, and consequently the main center hole in the backing plate, is slightly larger on the 10-bolt. The best way is to flip them over and use them on the opposite sides, which allows you to drill all-new holes, rather than elongating the ones that are there.
I can't imagine modifying 9-bolt Saginaw backing plates to hold PBR calipers to a 10-bolt.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I have a set of new 10 bolt plates I'll swap you straight over for, LMK. No need to modify a set of good plates when you can have the right parts.
Ed
Ed
Thanks for the replies and thanks for the offer ed, but I was just wondering about the mod because I was looking at a rear end for sale and this is what he did to install the disc system. Just wondering how reliable the mod would be . thanks
Well without seeing how it was done, it would be hard to guess at that. Could be carefully and thoughtfully done, or it could be a hack job. It's all in the details.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I guess I am going to go with a 4th Gen Swap LS1 and I don't have to worry and I know what I have . Thanks folks Thread
morrow
Jan 13, 2024 12:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
