9" moser housing
Old Mar 11, 2007 | 05:28 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
9" moser housing
it just hit me that i have found a small snafoo here...
i bought a 9" housing axle package for the 82-02 f-body, but heres the thing
ls1 rear brakes (what it calls for, for least work involved) is a c clip axle, and a ford 9" isn't, my question is did moser leave somthing out, or have i severly overlooked somthing here???
any help is appreciated
thanks
Old Mar 11, 2007 | 09:55 PM
92ZZ3RS's Avatar
Car: 92 camaro rs
Engine: LS1, 426 rwhp 406 rwtq
Axle/Gears: 9" with 3.70's
i ordered a 9" moser complete package for a 82-92 camaro but with LS1 housing ends. everything bolted right up using stock LS1 brakes
Old Mar 12, 2007 | 02:26 AM
badgta's Avatar
Car: 1991 FORMULA
i was talking to slowls1 today and he told me that my ls1 rear kit isn't complete, he told me that they have three plates, all i have is the large backing plate for the drum park brake and the caliper braket, which would explain a few things....
it's a shame, orderinf a complete ls1 rear brake setup and then it not being complete, thats ebay for ya!
Old Mar 13, 2007 | 03:01 AM
badgta's Avatar
Car: 1991 FORMULA
damn it
does anyone have a part number for the smaller backing plate? i have the ones that the ebrake shoes go on and the caliper bracket, but i guess it's the shim or somthing?
please help!
Old Mar 13, 2007 | 06:28 AM
84TranzAm's Avatar
Car: 84 TA Black/ Gold
Engine: 383 With Vortec Heads
Transmission: 700 R4 Lvl2 Performabuilt 9.5 Vert
Axle/Gears: Moser 9" with 3.70
I am setting up the same rear end , I just have not picked up my housing yet it is at the terminal and it is a 3hr drive. So probaly do that saturday. I was on the phone with Moser yesterday asking about brake set up. If you got your brakes off a 93-97 LT1 set up you have to use a shim, to use the LT1 set up. It should be included with your housing with directions and all. If you use brakes off of 98-2002 LS1 it is an LS1 set up and you do not have to use the shim kit. The LS1 set up uses the housing bracket with a backing plate attached to it then it holds a set of shoes that are the emergency brakes set up. I thought the backing plate and the bracket were all in one, but you must be missing the housing bracket. I will add some pictures I found , which are the LS1 set up. Is this what you have in the pictures? I am using the LT1 set up myself. Just for e-brake cable issues. Hope this helps you , Roger
Attached Thumbnails 9" moser housing-rotors-rear-view.jpg   9" moser housing-rotors-frontview.jpg
Old Mar 14, 2007 | 01:44 AM
badgta's Avatar
Car: 1991 FORMULA
well i got to looking at the instructions today and the axles use the brake caliper bracket to hold the axles in..... which is weird because if you do not press it on just right it could cause problems with things lining up.... it's defanantly going to be a interesting assembly to say the least
Old Mar 15, 2007 | 12:24 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
the backing plate once pressed on can flip flop around a little at the end of the axle to be bolted on properly, just make sure you bolt them facing the right direction and the proper LH and RH plates are on the proper axles.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
